We recently started getting a "File not Saved" error on one of our projects when saving to central. It was working fine, then just gave that error.
We first used one users local file (fortunately there's only one person really working on it right now) and made a new central file. We just saved over the existing central and this seemed to work fine at first, save to central was functioning, etc. However, after about 2 days it started doing the "File not Saved" thing when saving to central.
This time we re-created the central and immediately the STC did not work. That's when I submitted to support and came on the forums to try to find the problem.
I saw here some mention that you shouldn't overwrite the existing central, you should just make a new one with a new name so we tried that. That seemed to work at first, so I hoped that we had fixed the problem, but after a couple hours of work the same thing happened.
I am not sure what to do next. I know we've had memory issues in the past that caused this error, but I'm pretty sure that's not it this time. We can save locally just fine, task manager shows low memory usage, and this is a small project in schematic design, so the file is only 16mb.
Does anyone know what might be happening? Have not received a response from Autodesk yet.
