Thread: Mirrored blocks are not replaced in BLOCKREPLACE
    2018-10
    5
    Default Mirrored blocks are not replaced in BLOCKREPLACE
    Is there a way to have mirrored blocks replaced when using the blockreplace command? I can get it to replace blocks in the original configuration, but with my dynamic blocks that have been mirrored, they won't replace.
    Tallahassee, FL
    3,397
    Default Re: Mirrored blocks are not replaced in BLOCKREPLACE
    Not a normal thing to do with dynamic blocks, but a few options here: https://forums.autodesk.com/t5/dynam...4304810#M15392
    Did you search in the Forum: Dynamic Blocks - Technical? http://forums.augi.com/forumdisplay....ocks-Technical
    Ph# (850)606-1516 Home Page
  1. 2013: Blockreplace
    By jaberwok in forum AutoCAD General
    Last Post: 2015-12-13, 12:15 PM
  2. Replies: 0
    Last Post: 2011-11-23, 03:50 PM
  3. Select Blocks when using BLOCKREPLACE
    Last Post: 2008-10-11, 08:48 PM
  4. Blocks and mirrored text.
    By H-Angus in forum AutoCAD General
    Last Post: 2006-07-25, 07:02 PM
  5. Avoid Mirrored labels within blocks
    By jsilva in forum AutoCAD General
    Last Post: 2006-01-05, 12:37 AM
