Thread: Design Component Manager
    2015-12
    Near Charlotte, NC (Clover, SC)
    112
    Question Design Component Manager
    I am trying to rotate a triangular anchor for masonry construction so it is in plan view instead of section. I can't figure out a way to rotate it...I have done xflip, yflip, rotate option...
    Here is the command line when I insert the object w/ a picture attached.
    Command line: Insert point or [Base point/Rotate/Xflip/Yflip]:
    Any help? Any suggestions?
    Thanks in advance!
    2005-07
    2,356
    Default Re: Design Component Manager
    Quote Originally Posted by cadpro78 View Post
    Thanks in advance!
    If it's drawn in plan view then when you insert the detail go to the properties palette (ctrl + 1) and change the view from section to plan.
    It depends whether it's drawn in plan or not.
    100 Club cholmes's Avatar
    2003-02
    Omaha, NE
    198
    Yes, this is where the properties pallette is your best friend! Open it and leave it open, dock it to the side, whatever. There are a ton of options when inserting detail components that are only available there.
  1. Replies: 1
    Last Post: 2012-04-28, 05:31 PM
  2. Detail Component Manager
    By ssmith.62044 in forum ACA General
    Last Post: 2008-12-03, 03:29 PM
  3. Detail Component Manager
    By ekohles in forum Its all in the Details
    Last Post: 2008-05-24, 07:58 AM
  4. 3D Component Manager
    By cadkiller in forum ACA Wish List
    Last Post: 2006-07-26, 02:03 PM
