Thread: Keyboard Shortcut Keys
    2004-12
    80
    Default Keyboard Shortcut Keys
    Is there a way to set up keyboard shortcut keys using keys other than the accelerator keys? For instance:
    I want to set it up so that DF will perform a Draworder Front command. So I want to be able to type DF, then be able to select an object and have it come to the front. I cannot figure out a way to do this. I am fairly certain that I can do it if I assign one of the accelerator keys to it... but shouldn't I be able to assign whatever keys I want to be the shortcut keys?
    Part of the problem I am having is that there needs to be user input in the middle of the process (to choose which objects to bring to the front) and I can't figure that out. I can set it up so that when I type DF it goes to the Draworder command but then I am getting hung up every time at that step.
    I have tried this using CUI (I even found the macro assigned to the command: (^C^C^P(ai_draworder "_f") ^P). I tried doing it in the PGP file. I tried doing it in the ACAD2008.LSP file that runs at startup. I just cannot figure it out.
    HELP?? Anyone??
    Thanks
    2003-12
    Pittsburgh, PA
    355
    Default Re: Keyboard Shortcut Keys
    Put this in your acaddoc.lsp or acad2008.lsp file
    (defun c:df ()
    (setq ss (ssget))
    (command "draworder" ss "" "F")
    2004-08
    Iron Station, NC
    3,198
    Quote Originally Posted by lpseifert View Post
    (defun c:df ()
    (setq ss (ssget))
    put it in your acaddoc.lsp, NOT your acad2008.lsp, it is an AutoDesk file and is subject to be overwritten during repairs or updates
    2004-07
    Detroit Michigan
    2,508
    Interesting idea. I could see how that would be quicker than doing
    a right click to get the shortcut menu with draworder.
    I am always going to "select bring to the front"
  1. Shortcut keys
    By Wish List System in forum NavisWorks - Wish List
    Last Post: 2017-08-17, 10:52 PM
  2. Shortcut Keys
    By daniel.rushton in forum AutoCAD Customization
    Last Post: 2009-05-10, 11:12 PM
  3. Hotkeys vs Shortcut keys
    By kathy71046 in forum Revit - Platform
    Last Post: 2008-08-28, 02:43 AM
  4. Shortcut Keys for Number Pad
    By jabamax in forum AutoCAD CUI Menus
    Last Post: 2008-05-30, 02:59 PM
  5. Create own Shortcut Keys
    By basha_sk312 in forum AutoCAD CUI Menus
    Last Post: 2006-03-15, 08:37 PM
