Results 1 to 6 of 6
Thread: Aerial Image in print view only
    2005-07
    5
    Angry Aerial Image in print view only
    When we print our 2nd Floor ceiling plan, an aerial color view of an unrelated site appears and prints also. This background view only shows in "Print" or "Print Preview".
    We can not find any way to delete it or find out what it is referenced to. Any ideas?
    We have looked at visibility settings, managed links, etc, to no avail.
    So far does not appear in any other view.
    AUGI Addict truevis's Avatar
    2004-07
    Massachusetts, USA
    1,191
    Default Re: Aerial Image in print view only
    If you duplicate the view, does is still appear?
    Is the view on a sheet?
    Could the image be from a DWG?
    2006-04
    Baltimore, MD
    380
    Do you have an element temporarily hidden in the view? When you open up the view, is there a cyan border around the screen? This would cause something to be hidden on your screen, but show up when you print.
    2005-07
    5
    Image always appears in print preview or print views only.
    Does not show any where else.
    we can not "grab" it in any way either to find out what it's properties are.
    2005-07
    5
    Does not show up as "Hidden element" or Category.
    We have been able to eliminate image from Print Views by changing "View Range" in View Properties.
    However, is there any way to find out what images have been inserted, imported or linked to a drawing
    All AUGI, all the time gwnelson's Avatar
    2003-04
    Westchester County, NY, USA
    612
    Check dropdown menu from FILE ----> Manage Links.
  1. 2013 Applying aerial image base in timeliner NW crashes.
    By jobwallis724305 in forum NavisWorks - General
    Last Post: 2013-11-12, 05:03 PM
  2. 2013 Strange grid lines on aerial photos. don't print but annoying to work with.
    By kscolfer in forum AutoCAD Map 3D - General
    Last Post: 2013-08-26, 07:37 PM
  3. 2013: Aerial image used as decal obscuring model
    By gregb in forum Revit Architecture - General
    Last Post: 2013-02-11, 03:44 PM
  4. Adjusting an Aerial Image Material
    By jason.combs in forum VIZ - General
    Last Post: 2008-04-09, 01:28 AM
  5. RD 2008 Aerial Image Anomalies
    By Spokes in forum Raster Design - General
    Last Post: 2008-02-08, 08:51 PM
