Thread: Calculate Building Volume?
    All AUGI, all the time mmiles's Avatar
    2006-03
    New York, NY
    559
    Default Calculate Building Volume?
    I know that I can get volume calculations for rooms, and apparently for objects - like wall assemblies- but is it possible to have Revit calculate a building's total volume? If so, how does it work and where can I schedule that?
    T.I.A.
    2015-12
    Vancouver, BC Canada
    3,753
    Default Re: Calculate Building Volume?
    Probably the easiest way is to use masses.
    2006-03
    New York, NY
    559
    Thanks, massing is exactly what I have done- even had the masses already done (mostly) from the "conceptual" phase.
    Is there a way to schedule this, with totals, or do I need to manually enter numbers?
    Last edited by mmiles; 2008-02-26 at 06:14 PM. Reason: Never Mind- I see the schedule type.
    2015-12
    3,753
    Create a mass schedule and volume will be available as one of the parameters
  1. Calculate the Volume of a Container
    Last Post: 2013-02-20, 09:56 AM
  2. Calculate Interior Volume
    Last Post: 2008-02-03, 04:20 AM
  3. Does Building System calculate for fire protection?
    By K.TYSON in forum AMEP General
    Last Post: 2007-03-08, 07:32 AM
  4. Calculate a Volume at an elevation for a TIN
    By cjtrull in forum VBA/COM Interop
    Last Post: 2006-02-25, 07:24 PM
  5. Calculate Room Volume
    By Michael Coviello in forum Revit Architecture - Tips & Tricks
    Last Post: 2003-11-13, 11:07 PM
