Results 1 to 1 of 1
Thread: Network Flood Analysis
    2005-12
    90
    Default Network Flood Analysis
    When doing flood analysis, is it possible for the nodes to change color like the lines do? I am trying to make sure the linework flows through the nodes.
    Thank you,
    TC
    Here is my duct tape solution.
    Create a block with lines (in this case 10 ft long) radiating from a central point; make that point the insert point.
    Export your current nodes to a point shape file (no data needed).
    Import points and use the block just created.
    Explode those blocks.
    Make network topology of your current topology lines and the exploded block lines.
    Run a flood topology, if the exploded block lines do not change color they are not connected.
    (current experiment)
    Make a buffer topology and export the polygon shape.
    Import and use to cover up areas that do not need fixing.
    (better choice)
    Query the Flood Buffer and Alter the Layer and turn the layer off.
  1. 2014: "Edit in Storm and Sanitary Analysis" will not Extract My Network....
    By aspencer.226869 in forum AutoCAD Civil 3D - Pipes
    Last Post: 2014-05-09, 05:35 PM
  2. Flood Trace Analysis
    By amorris.120609 in forum AutoCAD Map 3D - General
    Last Post: 2006-09-19, 07:58 AM
  3. Flood Trace Analysis
    By amorris.120609 in forum AutoCAD Map 3D - Wish List
    Last Post: 2006-09-15, 03:25 PM
  4. Network topology analysis
    By bprabhakar001 in forum AutoCAD Map 3D - General
    Last Post: 2006-06-21, 07:23 AM
