Thread: Materials Look Hazey When Rendered
    100 Club jason.combs's Avatar
    2005-08
    St. Louis, MO
    173
    Default Materials Look Hazey When Rendered
    I am using VIZ 2008 and using mrSun/mrSky to create an exterior rendering of a building. My problem is that my finished materials are a hazey version of the ones represented in the Material Editor.
    The attached image depicts the rendered material on the left and the material editor version on the right.
    Any thoughts?
    Design Visualization Moderator stusic's Avatar
    2004-10
    Denver, Colorado
    1,514
    Default Re: Materials Look Hazey When Rendered
    I think the color of the sun/sky system is affecting the perceived colors of the brick wall (and other materials). I believe the default colors for the s/s sytem is nto true white, but a yellow color. This is what I believe is changing the look of your render. Try changing the color of your s/s system to a true white, then re-render.
    Hope this helps; if it doesn't, let us know!
    Phillip Bradshaw
    Lead Pixel Pusher, Lucid Design Studio
    CAD Detailer, Proctor Productions
    A doctor can bury his mistakes but an architect can only advise his clients to plant vines. - Frank Lloyd Wright
  1. Convert Mental Ray materials to Standard Materials?
    By cliff collins in forum 3ds Max - General
    Last Post: 2011-04-11, 04:59 PM
  2. Materials - add an image to the rendered appearance?
    By abe.buckingham in forum Revit - API
    Last Post: 2010-07-15, 05:00 PM
  3. Revit materials replaced by Max materials, upon import
    By narlee in forum Revit - Rendering
    Last Post: 2010-07-09, 01:59 PM
  4. RAC 2009 - rendered section materials rotated
    By ws in forum Revit Architecture - General
    Last Post: 2008-05-23, 01:57 PM
