Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
Thread: Autocad Benchmark using Cadalyst 2008 - Results
  1. #11
    2003-07
    Denver, CO
    2
    Default Re: Autocad Benchmark using Cadalyst 2008 - Results
    I just go a new HP 8710 Mobile Workstation. So far this computer is a solid investment. The time savings will pay for it in a few months.
    OS Platform : XP SP3
    AutoCAD version : 2009
    Graphics Window size : 1280x1024
    Test Date (Time) : 8-14-08
    Computer Brand : HP Compaq 8710w Mobile Workstaion
    CPU Type : Intel Core 2 Duo T9500 @ 2.6GHz
    System RAM : 4.0GB (only 3GB are recognized as "freee")
    Graphics Card : nvidia Quadro FX 1600m
    Graphics Card driver : 6.14.11.6758
    Number of Test Loops : 1
    C2008 Total Index = 191
    3D Graphics Index = 218
    2D Graphics Index = 261
    Disk Index = 97
    CPU Index = 187
    Single Loop Time = 61 min
  2. #12
    2004-11
    29
    Dell precision 390
    Intel Core 2 Duo 1.86GHz, 2GB ram
    768MB nVidia Quadro FX4600
    Driver Version 6.14.11.6996
    OS Windows XP SP2
    AutoCAD 2009
    C2008 Version 5.1 (July, 200
    C2008 Total Index = 268
    3D Graphics Index = 677
    2D Graphics Index = 167
    Disk Index = 106
    CPU Index = 121
    Single Loop Time = 30 min.
  3. #13
    2006-01
    Southern Sawatch Range, High Rockies
    2
    Dell Precision 530 MT
    Dual Xeon 1.7 GHz
    3DLabs Wildcat II 5110
    Driver 6.5.006.18
    Dual SCSI Quantum Atlas 36 drives
    XP Pro SP3
    4 GB (3 GB switch)
    ADT 2007 SP1 standalone installation
    C2008 v5.0
    Tried running combined 3D/2D fo 20 hours -- no go.
    2D only:
    2D index = 34.6
    Disk Index = 61.2
    CPU Index = 41.5
    Single Loop Time = 72 min.
    Trying to run 3D alone now -- not looking good.
    I'm evaluating this old workhorse with an eye toward buying it as a stopgap machine until I can afford better. Performance is underwhelming. I'm thinking I'll have to at least upgrade the graphics card & drives, which makes the purchase price of $1,400 for the workstation seem unreasonable.
  4. #14
    2008-06
    6
    OS: Vista Business 32-bit
    Autocad Version: Map 3d 2009
    Resolution: 1680x1050
    Computer Brand: Xi Custom Build
    CPU: Core2Duo 3.17Ghz
    RAM: 4.0GB
    Hard Drive: 150G WD Raptor 10000RPM
    Graphics Card: Pny Overclocked 8600 GT 512M
    Graphics Card Driver: 7.15.11.7824
    Total Index: 170
    3d Graphics Index: 137
    2d Graphics Index: 181
    Disk Index: 164
    CPU Index: 196
    Single Loop Time: 78 min
    Marty Drabic
    Hill Engineering, Inc.
  5. #15
    2008-06
    52
    thanks for sharing everybody... that is great info!
    See attached: this is a mix of Dell 380/390/T3400 (8 workstations). All the video cards are Nvidia Quadro's. Most systems have the 3G switch set.
    C2008 V5.1
  6. #16
    2008-10
    40
    OS Platform : Vista 64bit sp1
    AutoCAD version : 2009 update 2
    Computer Brand : Custom build. motherboard GA-EP35-DS3P
    CPU Type : Intel Core 2 Duo E8600 3.33GHz @ 4.3GHz (overclocked)
    System RAM : 8GB 800MHz @ 860MHz
    Harddrive: 300GB WD Velociraptor
    Graphics Card : ATI FireGL 3600 256mb @ 729mhz gpu, 585mhz ram (overclocked)
    Graphics Card driver : 8.501.0.0
    Enhanced 2d performance and texture compression = off
    Surfaces and Curves slide bars at low detail
    Adeskhardwarecompatibility list version 17.2.0.5
    Graphics Window size : 1024x768
    C2008 Total Index = 302
    3D Graphics Index = 302
    2D Graphics Index = 422
    Disk Index = 200
    CPU Index = 284
    Single Loop Time = 32 min
    Graphics Window size : 1920x1200
    C2008 Total Index = 273
    3D Graphics Index = 180
    Disk Index = 207
    CPU Index = 282
    Single Loop Time = 37 min
    Graphics Window size : 3840x1200 (2x 24" monitors)
    C2008 Total Index = 263
    3D Graphics Index = 148
    2D Graphics Index = 424
    Disk Index = 193
    CPU Index = 286
    Single Loop Time = 40 min
    The larger screen size reduces the 3D Graphics Index quite a bit.
  7. #17
    2009-03
    2
    Thumbs up Re: Autocad Benchmark using Cadalyst 2008 - Results
    Hello all,
    I am completely new to AutoCad, and I am working on a performance theory in my lab. I have downloaded the 30 trial of AutoCAD 2009, installed it, loaded the Cadalyst 2008 files, and the instructions included appear to be for AutoCAD 2008, and I want to make sure that the results I am seeing are valid for the benchmark.
    Can anyone PLEASE help me with how to run the 2D and 3D suites inside AutoCAD 2009. I can get the 'robot' to load, and when I type GSTESTBenchmark, it runs thru a 'script' and the image rotates, etc. but, I'm not sure that is the complete test, etc.
    Any assistance you could provide me regarding this would be a HUGE benefit for my application theory.
  8. #18
    2008-10
    40
    The instructions are valid for 2009 too. In the readme file Readme_C2008_v5.1.txt under getting started section, it says to rename GFXTEST_xxxx.ARX as GFXTEST.ARX. I am using 64bit autocad2009, so I renamed gfxtest_acad2009_64bit.arx to gfxtest.arx
    Then setup the 3d settings by typing 'options', go to the 'system' tab, click 'performance settings' and turn off 'adaptive degradation', then click 'manual tune' and set 'number of tessellations to cache' to 10. enable 'hardware accelaration' and set 'driver name' to direct3d for vista, or opengl for xp. You may want to click 'check for updates' to get the latest hardware compatibility list.
    Then you set sdi to 1 by typing sdi enter 1 enter, then restart autocad, then type appload, browse to the cadalyst directory, select C2008_go.lsp and click load then click close, and thats how the test is run.
  9. #19
    2009-03
    2
    Ok, After painfully learning how to run this benchmark (never used AutoCAD before this experiment)
    Here are my results:
    C2008 Total Index = N/A
    3D Graphics Index = N/A
    2D Graphics Index = 310
    Disk Index = 196
    CPU Index = 276
    Single Loop Time = 10 min
    I think it would have gone even faster, but, I noticed the 'pauses' placed within the test, and I believe that added to my overall time...?
    The other part is that I believe I saturated my CPU with data, and that even with my Quad Core CPU, I think my bottle neck was my processor.
    More tests coming! Thanks for your help with this experiment!
    Last edited by msanor; 2009-04-21 at 07:16 PM. Reason: Left part out... I could not make the 3D test run... It said something about unable to upack file...?
  10. #20
    Cairo - no, not Illinois
    5,069
    Quote Originally Posted by msanor View Post
    Since you're new to Acad, you probably are not aware that AutoCAD takes very little (that is, damn near none!) advatage of multiple cores. So an Acad benchmark should give failrysimilar results whether one or four cores is available. A second processor is helpful for off loading the MSWindows background cruft, but does not directly benefit Acad, except in a few specific instances e.g. rendering.
    Try running the same benchmark with Task Manager open, and watch one processor slam while the others barely twitch. And if your BIOS lets you, try disabling the 2nd thru 4th cores and compare results.
  1. Ideas for a 2D benchmark routine for 2007 or 2008
    By GreyHippo in forum AutoLISP
    Last Post: 2008-07-05, 03:42 PM
  2. Render Benchmark Results
    By christopher.zoog51272 in forum Revit - Hardware & Operating Systems
    Last Post: 2008-05-16, 11:24 PM
  3. April 2008 Cadalyst mag
    By Steve_Bennett in forum DV - The 3rd Dimension
    Last Post: 2008-04-11, 08:49 PM
  4. AutoCAD 2008 - Plotting to PDF results in a shift on the output
    By ehabgeorge in forum AutoCAD Plotting
    Last Post: 2007-06-18, 05:55 PM
  5. Benchmark results make no sense...
    By patricks in forum Revit - Hardware & Operating Systems
    Last Post: 2006-06-26, 06:53 PM
