Thread: Gear Design
    2004-08
    16
    Exclamation Gear Design
    i know i will probably be tarred and feathered for asking this question in the wrong forum but the inventor forum is locked... i am trying to extrude a gear in inventor 9. the dimensions are fine before array, but after array the auto dimension is showing one dimension missing. and when i try to select for extrusion i cannot select anything. i'm sure the geometry is correct. what am i doing wrong? any ideas?
    maybe there is some format for designing gears in inventor?
    thanks
    doug
    2015-12
    Arizona
    2,337
    Default Re: Gear Design
    This link suggests your gears should be
    designed in one of the two shaft generator tools.
    http://usa.autodesk.com/adsk/servlet...linkID=4183228
    This link is a host of tutorials for you, none appear to be
    specific towards gears.
    http://usa.autodesk.com/adsk/servlet...linkID=4183230
    150700
    3,434
    Quote Originally Posted by dougsilvi
    thanks
    doug
    The inventor forum is not locked. There is no general inventor forum - there are sub forums, and those are all open. Let me know where you want this post, and I will be glad to move it to the correct forum - and for the record no one has ever been tarred or feathered for posting to the wrong forum - only whipped lightly with a cooked noodle
    2004-08
    16
    Smile Re: Gear Design
    Thanks CADGIRL and MJ
    i will get the hang of this forum before too much longer
  1. Gear Software
    By GABEDRUMMIN942632 in forum AutoLISP
    Last Post: 2012-09-21, 05:56 PM
  2. Gear width too big
    By eli_lied in forum Inventor - General
    Last Post: 2009-05-29, 01:54 PM
  3. Gear Table
    Last Post: 2009-02-07, 05:47 AM
  4. Gear Design - Create Hubs on Gears
    Last Post: 2008-10-07, 02:19 AM
  5. helical gear trouble
    By info.78032 in forum MDT - General
    Last Post: 2004-11-15, 05:21 AM
