Thread: Revit Revision Number not automatically populating
    I could stop if I wanted to tonyisenhoff's Avatar
    Milwaukee, Wisconsin
    424
    Default Revit Revision Number not automatically populating
    Anyone have this happen before?
    This has happened now on two different projects now where we're using the revision cloud tool, but Revit is not providing a revision number when you tag, and the revision schedule in the title block does not show a number. It shows the date & description, but not the number. We're doing our revisions "Per Sheet".
    Yes - the view is placed on a sheet, so it should fill out.
    Our workaround is to cut/paste "same place" the cloud, THEN the number fills out. Any new clouds are blank... till we cut/paste.
    Any suggestions?
    2001-12
    Irvine, CA
    7,567
    Default Re: Revit Revision Number not automatically populating
    Reported this to Autodesk in December, it is a known issue (now at least), and posted to HOK's blog as I was there when we ran into it. We also resolved with Cut/Paste etc as you described. After reviewing the issue this is what Autodesk reported back:
    Quote Originally Posted by Autodesk Support
    This appears to be the result of an interaction between the Annotation Crop and the Revision numbering mechanism. This has been reported in a few cases before this. I will log this problem and you will be updated on the progress of this.
    The workaround for this is to go to the View Properties for the view with the Tag in it and turn off Annotation Crop. Insert your Revision Tag. Your Tag should now be visible but your annotation is now visiable every where. Go back into the View Properties and turn Annotation Crop back on. This should fix your problem.
    424
    Steve - thanks for the reply...
    I did open the project in the preview of 09 and the issue wasn't there. I didn't even have to go thru the cut/paste... it was just fixed and any new clouds worked as expected.
    So, looks like it's fixed.
    2008-04
    LA area
    147
    Still an issue in v2021.
  1. Revision Cloud With Number
    By SHAJU in forum AutoLISP
    Last Post: 2009-05-20, 07:50 PM
  2. Replies: 7
    Last Post: 2008-01-29, 06:11 PM
  3. Option to Automatically Number Sheets
    Last Post: 2007-09-28, 12:43 PM
  4. Automatically number blocks?
    By tsapp in forum AutoCAD General
    Last Post: 2006-10-20, 09:13 AM
  5. REVISION NUMBER
    By Alvin_Alejandro in forum Revit Architecture - General
    Last Post: 2005-05-12, 02:54 PM
