Thread: Trim :Selecting entites on the Screen without Selection.
    2007-05
    23
    Default Trim :Selecting entites on the Screen without Selection.
    The Following procedure is useful when you need to trim a lot of in-between entities in a random fashion.
    In the Trim Command during “select objects” prompt just give a blank entry
    All the entities on the screen is selected for trimming
    During trimming process even if u pan the screen the objects seen on the screen is will
    Become active selection set.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: Trim :Selecting entites on the Screen without Selection.
    Thanks for sharing. I agree, it's a good tip.
    Blue Springs, MO
    658
    Quote Originally Posted by balubharadwaj View Post
    Becarefull if you have projection turned on. Splines will project out hundreds of lines and you'll be trimming forever
  1. Replies: 0
    Last Post: 2012-04-18, 05:43 PM
  2. AutoCAD splash screen selection
    By arshiel88 in forum AutoCAD General
    Last Post: 2011-02-08, 01:30 PM
  3. Trim, trim objects/selection issue 2010
    By stevej.57608 in forum CAD Management - General
    Last Post: 2009-07-08, 04:09 PM
  4. Selection is only what is visible on screen
    By nel in forum AutoCAD General
    Last Post: 2007-09-24, 03:10 PM
  5. Add/remove to selection from screen
    By Martin P in forum Revit Architecture - Wish List
    Last Post: 2005-03-10, 02:13 PM
