Thread: Won't display cursor coords
    2008-02
    Default Won't display cursor coords
    I am using AutoCAD v14 and don't seem to be able to get it to dynamically display the cursor coordinates. I have toggled the COORDS on & off using both Control D as well as F6, but the cursor coordinates do not display on the screen. Any suggestions? Also, is there any way to be able to click on an icon to change to the ortho mode when drawing, as it is cumbersome to have to type in "ORTHO" and then "On or Off" whenever switching in & out of this mode. Thanks.
    2005-07
    2,356
    Default Re: Won't display cursor coords
    Quote Originally Posted by wdyoung View Post
    R14 doesn't have dynamic input.
    F8 toggles ortho.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,463
    Quote Originally Posted by H'Angus View Post
    F8 toggles ortho.
    I think the OP is referring to the status bar at the bottom of the drawing. The system variable COORDS is supposed to handle this. I can't think of anything else at the moment.
    2015-11
    Jo'burg SA
    4,512
    From the help:
    Controls the format and update frequency of coordinates on the status line.
    The absolute coordinates of your pointing device are updated only when you specify points
    The absolute coordinates of your pointing device are updated continuously
    The absolute coordinates of your pointing device are updated continuously except when a point, distance, or angle is requested. In that case, relative polar coordinates are displayed instead of X and Y. The Z values always display as absolute coordinates.
    So you probably want COORDS set to 2.
  1. Using fields in a block to display x,y coords
    By ajzoch in forum AutoCAD Fields
    Last Post: 2017-08-08, 11:28 AM
  2. No UVW coords when exporting
    By dpasa in forum Revit - Rendering
    Last Post: 2010-02-18, 06:31 AM
  3. display relative coords???
    By Forsh in forum AutoCAD General
    Last Post: 2009-05-25, 02:51 PM
  4. x,y coords and fields
    By Maverick91 in forum AutoCAD Fields
    Last Post: 2008-10-28, 07:44 AM
  5. shared coords
    By hanff in forum Revit - API
    Last Post: 2008-09-20, 08:05 PM
