Thread: Import Dwgs and Sheet Set info into another sheet set
    2004-06
    IL
    19
    Default Import Dwgs and Sheet Set info into another sheet set
    If you send engineering drawings to an architect and both people use sheet sets, can the architect import the engineering sheet set into their sheet set, so that the engineering drawings would be part of the architect's sheet set, and the architect's sheet set would now have the information for the engineering drawings so that the fields in the engineering drawings still work?
    Almost like combining two sheet sets into one.
    Or is this something I will have to custom program?
    Retired Forum Staff Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    Default Re: Import Dwgs and Sheet Set info into another sheet set
    Quote Originally Posted by jschultz View Post
    when zipping them up (eTransmit), i recall seeing some options for including SSM information. i would run a trial just to be sure, but can't be possitive that's what it's there for.
    S&D DB Sharing Forum
    100 Club jamie.casile80054's Avatar
    2004-12
    rock in the middle of the Pacific
    191
    i believe it is something that will need to be programmed. i would be very interested to see this work! cool idea.
    Jamie Casile
    CAD/BIM Manager
    Pacific CADD Services, Inc.
    ...My Lomography Page...
  1. Revit- sheet template info
    By freebrd1230363390 in forum Revit Architecture - General
    Last Post: 2013-03-04, 01:54 PM
  2. Create Sheet Lists and Total Sheet Count for Subsets in Sheet Set Manager
    Last Post: 2008-10-12, 06:30 PM
  3. plotting mutiple DWGs on one sheet.
    By dnasalroad in forum AutoCAD Plotting
    Last Post: 2008-08-01, 06:13 PM
  4. AutoCAD 2007 - Create Sheet Set only includes 3 DWGs from a folder of 7
    By SemperLibre in forum AutoCAD Sheet Set Manager
    Last Post: 2006-10-21, 07:16 AM
  5. Replies: 3
    Last Post: 2006-04-26, 02:35 PM
