Thread: Call a Private Sub from another userform
    2003-10
    706
    Default Call a Private Sub from another userform
    How can I use a user defined Private sub from another userform? I want to be able to click on a button from one userform and have it go to another userform's private sub to calculate something for me and then return to the original userform. I'm sure this is very easy. Do you do this in a module?
    Turlock, CA
    6,409
    Default Re: Call a Private Sub from another userform
    As long as you've got it declared as private, the form would have to initiate the call. Either make the procedure public or create another public sub that can call it. Whether the calling code is in a regular module or another form's class module makes no difference as to the scope of the source procedure.
    C:> ED WORKING....
    LinkedIn
  1. Parameters from Userform
    By CADfunk MC in forum VBA/COM Interop
    Last Post: 2010-04-26, 06:25 PM
  2. All I want is a Userform to show..
    By Coolmo in forum Dot Net API
    Last Post: 2009-07-23, 02:03 PM
  3. VBA userform in excel
    By Streng in forum VBA/COM Interop
    Last Post: 2009-02-17, 07:02 PM
  4. Userform sizing
    By Coolmo in forum VBA/COM Interop
    Last Post: 2006-05-30, 11:30 PM
