Hi,
I am using Autodesk MEP 2008.
I am having some problems getting the attributes in my annotative dynamic blocks to scale properly every time they are inserted into a drawing..
If you open the attached DWG file and drag the dynamic block onto your tool palette, and then insert this DB block into a new drawing, it will scale properly only the first time; you can insert the block into that same drawing as many times after that, and the attributes will not scale properly; the only way I can make it work, is if I use the command “batman”, then I can synchronize the block and it will work. This doesn’t seem normal, anyone have any ideas??
Also, if you insert the block into a drawing, and then you change the annotation scale a couple of times, and then select the dynamic block in the drawing, you will notice that it has shadows – I use the term shadows for this bizarre occurrence - it seems to remember the size of the block for every annotation scale it was scaled to – is this normal or am I doing something wrong?
If you hover over the block, you will see two annotative symbols, which doesn’t seem normal, and I think this is causing the dynamic block to have shadows??
Thanks for any help
