Thread: Standard templates
    2007-05
    25
    Question Standard templates
    I am Tuturing ACA2008 at SIT in Invercargill New Zealand.
    I decided this year to use the standard settings taht came with ACE in regards to the project navigator templates.
    I am using the construct template - Aec Model (MetricCTB).dwt file to creat my constructs.
    i have set up a project with 2 levels.
    1 starting at 0 and the next at 2.42m
    I am having problems with the display between levels of the constructs.
    I created a construct for the floor model and then a constrcut for the roof model. the house house brick veneer and timber framed walls.
    but when I bring drag the floor model into my roof construct which is on a different level it shows the display of the walls differently.
    What would be cause this
    Any help would be appriciated
    cheers
    phil
    2006-12
    Big "D"
    3,711
    Default Re: Standard templates
    It could be a number of things. The first one that comes to mind is the cut plane. Since you are dragging it to the roof level, the cut plan will be above the walls. Change the cut plane @ the bottom right corner of the task bar to ................well.................. my mind only works in imperial!!!! Just imagine that if the walls are only 2 meters high, then the cut plane needs to be below that. See if that helps.
    You could also drag the roof into the floor construct. That way the cut plane would be correct, and you should still see the outline, ridges, and valleys of the roof.
    2007-05
    25
    Yeah i had a small play with that but it did not seem to changed the display of the floor plan. I thought it might be something to do with the cut plane. It is strange as I use my own template for work an it is as good as gold but it is not built up from the latest release of ACA it is built from an old one.
    Cheers
    2006-12
    Big "D"
    3,711
    Quote Originally Posted by archdraught View Post
    Cheers
    You should definately recreate your templates starting with an ACA template. There's a whole bunch of stuff written into the ACA tempates that are OOTB. Display configs, anno scales, etc. The old templates just don't usually work as well. I know you said your's works, but I'd still create a new one so that all the display configs, etc. are there.
    2007-05
    25
    Yes it work this time when i changed the elevations to be 1.4m in the roof structure construct cheers for your help
  1. 2014: Setting Up Project Templates & View Templates???
    By sbrennan in forum Revit MEP - General
    Last Post: 2013-08-29, 09:17 PM
  2. Standard AutoCAD templates
    By Mac Demer in forum AutoCAD General
    Last Post: 2010-01-24, 07:07 AM
  3. Replies: 4
    Last Post: 2006-09-21, 02:56 PM
  4. Creating Standard View Templates...are they worth it?
    By cparsons in forum Revit Architecture - General
    Last Post: 2006-02-24, 04:06 PM
  5. Missing Project Standard Templates in ADT 2006
    By dbroughton in forum ACA General
    Last Post: 2005-04-30, 06:45 PM
