Thread: FLIP DIRECTION
    100 Club amaser's Avatar
    2006-05
    Joliet, IL
    105
    Angry FLIP DIRECTION
    It owuld really be nice, if in future versions, they put the Flip Diection back on the shortcut menu for lines.(The old _AEC_CIVIL_FLIPBEARING command)
    I'e seen some VBA and LISP routines that do esomething similar, but they don't work quite the same way, and I can't get them into the shortcut menu where I want them.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Default Re: FLIP DIRECTION
    This rev.lsp will reverse a selection of Lines & Polylines, instead of just one at a time. Let me know if you have any problems.
    After saving it in your support path, in the "LWPline Object Menu" under "Shortcut Menus" in the CUI add:
    Command name: Reverse Polyline
    Macro: ^C^C^P(or C:rev (load "rev.lsp"));rev
    2006-05
    Joliet, IL
    105
    that seems to work,although it didn't put the command in the right location of the list, but at least it's there, and it seems to work.
    Thanx
    2001-03
    Tallahassee, FL USA
    3,667
    Quote Originally Posted by amaser View Post
    Thanx
    I have the command in the following shortcut menus:
    LWPline Object Menu (single LWPline)
    LWPline Objects Menu (multiple LWPlines)
    Line Object Menu
    Pline Object Menu
    I added a few shortcut menus so you might not have all those. I use shortcut menus for almost all modifing. No more looking thru Toolbars and Drop-down menus, just right-click.
  1. Flip Direction for Pipes?
    By mdemint in forum AutoCAD Civil 3D - Pipes
    Last Post: 2020-02-27, 04:38 PM
  2. Flip Controls and Connector Direction
    By phyllisr in forum Revit MEP - Families
    Last Post: 2011-12-30, 07:11 PM
  3. Flip dimension direction
    By autocad.wishlist1734 in forum Inventor Wish List
    Last Post: 2011-10-20, 10:23 AM
  4. Flip line direction
    By dasmith in forum AutoCAD Civil 3D - General
    Last Post: 2009-07-25, 12:44 PM
