Thread: Color of border around cropped bitmap
    2005-06
    22
    Default Color of border around cropped bitmap
    In the material editor I have placed a bitmap on a cube sample. I want to use it as an image on the model of a sheet of paper draped over the edge of a table.
    It is a simple enough matter to have the bitmap entirely cover the sheet of paper, but in the interest of realism, most renderings and drawings have a margin and do extend to a bleed edge.
    I have cropped and placed the bitmap on the sample cube so that there is a "margin" showing on the cube around the bitmap. When I place it on the "sheet" it behaves well and renders with the expected margin.
    The problem I am unable to solve is that the color of the sample cube is gray. The gray of the sample cube maps onto the sheet and results in a gray margin around the bitmap. I am hoping someone knows how to alter the color of the cube itself to white. If I alter the Specular color to black in the Blinn Basic Parameters rollout I can change the color of the cube (and hence the margin in my rendering) to black. If I change it to white, however, the cube (and hence the margin in my rendering) only changes to a medium gray.
    I'm still looking for white. Any ideas? Thanks!
    Design Visualization Moderator stusic's Avatar
    2004-10
    Denver, Colorado
    1,515
    Default Re: Color of border around cropped bitmap
    Does it work if you change the Diffuse color to white?
    Phillip Bradshaw
    Lead Pixel Pusher, Lucid Design Studio
    CAD Detailer, Proctor Productions
    A doctor can bury his mistakes but an architect can only advise his clients to plant vines. - Frank Lloyd Wright
    2005-06
    22
    Thanks for asking.
    I was in there turning everything I could find to white. So, yes, the diffuse, ambient and specular colors are all set to white.
    On funny thing though, I am not getting bright white renders of objects (sheets of paper) that have a plain white standard material applied to them. But I am getting good bright white areas in the bitmaps applied to other objects.
    I have tried both mr and standard scanline renderers and spent a lot of time in the exposure settings. I can set exposure in either renderer to give a bright white to the standard white material objects, but then everything else is washed out.
  1. 2011: Bitmap images
    By eckardp in forum ACA General
    Last Post: 2010-09-16, 07:10 PM
  2. Replies: 1
    Last Post: 2010-01-24, 10:11 AM
  3. PDF to Bitmap
    By rjcrowther in forum Revit - Plotting/Printing/Exporting
    Last Post: 2007-01-22, 04:38 PM
  4. Bitmap textures
    By patricks in forum Revit - Rendering
    Last Post: 2005-11-20, 10:09 PM
  5. bitmap hatch
    By dryoco in forum AutoCAD General
    Last Post: 2005-02-11, 01:58 PM
