Hi
I'm pretty much a newbie on here. I recently purchased inventor 2008 pro and well, i'm teaching myself how to use it. there are a few things that i have run into that just do not seem to be intuitive or work the way that i think that they should work, so, i have some questions!
1) Using the design accelerator to create spur gears / shafts. I don't get it. lol. I'm sure there is a trick, but, i haven't been able to figure it out. I want two gears of a particular gear ratio.. I am limited by interferecence which limits the large gear diameter (well, it would with where i'd LIKE to put the gear, but, i could move its location along the shaft such that the gear diameter would not be an issue). So, my question is, how do i do this? Can i use the design accelerator to put one spur gear on one shaft, one on another?
The other question is why doesn't design accelerator give you a hole to put the gear on a shaft?
Basically, i just need a walkthrough on how the heck to properly use this feature. I'm trying to work through the documentation that i have, but, i'm hoping that somebody could quickly point me to a helpful tutorial or at least a good starting point...
Thanks a ton!
Wes
