Thread: Another Keynote question regarding formatting
    2003-09
    California
    400
    Default Another Keynote question regarding formatting
    I'm doing a list of keynotes for one of my projects and I was wondering if it is possible to put a line of text on a different line within the same Keynote?
    Currently the note reads:
    (N) METAL FRAME TO SUPPORT HOOD. HOOD CANNOT BE SUPPORTED BY (E) TRUSSES. FRAME=3 1/2"x14 GA. STUD + 6" X 14 GA. JOISTS.
    I would like to format it so that it reads:
    Is this possible? I've tried change the width of the column, however, this makes the rest of my keynotes way too long. Any suggestions?
    AUGI Addict PeterJ's Avatar
    2003-04
    London, UK
    1,948
    Default Re: Another Keynote question regarding formatting
    Type your text into notepad with carriage returns where required. then cut and paste into the appropriate keynote, it should bring the carriage returns through
    2003-09
    California
    400
    PeterJ, you are the master! This did the trick! Thanks for your quick reply.
  1. Replies: 1
    Last Post: 2016-12-06, 04:51 PM
  2. Keynote Formatting
    Last Post: 2012-11-13, 04:52 PM
  3. MText formatting question
    By darrellh in forum AutoCAD General
    Last Post: 2011-03-28, 09:18 PM
  4. Keynote Table Formatting
    By j_starko in forum Revit Architecture - General
    Last Post: 2010-11-24, 08:00 PM
  5. Formatting Fields in Keynote Table
    By dmcdonald.144953 in forum AutoCAD Fields
    Last Post: 2008-12-11, 06:00 PM
