Thread: Scale List Edit
    2006-07
    12
    Unhappy Scale List Edit
    Hi everyone, is there any way you can wipe out the unuse scale list forever. it's keep coming back every time i open the drawing. i already done the -scalelistedit to reset the open drawing & that's good i wipe out the scalelist that i don't want to. But when i open the drawing again it's back again. By the way i'm using AutoCAD 2008
    I already have installed the 2008 services pack sp1.
    Any one can help is much appreciated. Thank you.
    From Down Under.
    Earth
    9,788
    Default Re: Scale List Edit
    Ok, you have SP1 installed. That is the first step.
    Remember that the scale list entries are stored in the drawing, and SP1 only prevents scale list entries from nested xrefs from being imported. It does nothing to affect existing drawings.
    You have to clean ALL of your drawings starting from the bottom up. In other words, start at the lowest generation nested xref and work your way up to the parent. From that point on, only the scale list entries from the 1st level xref will be imported.
    AutoCAD 2009 includes a toggle to "hide" xref scale list entries.
    R.K. McSwain | CAD Panacea |
    2006-07
    12
    Thank you very much, i'll try that.
    cheers,
    2005-01
    58
    I have it setup in by pgp as SL. Everynow and then I run this but only on bigger jobs. It is quite a pain really.
  1. Edit List Box
    By bdrummond in forum AutoLISP
    Last Post: 2009-02-20, 01:31 PM
  2. Edit annotation scale lists
    By philcrocker in forum AutoCAD General
    Last Post: 2007-12-19, 07:18 PM
  3. Annotation Scale list keeps propagating the whole list
    By jacep in forum AutoCAD Annotation
    Last Post: 2007-12-13, 06:24 PM
  4. AutoCAD 2008 Delete scale from Annotation Scale list
    By cgerhardt in forum VBA/COM Interop
    Last Post: 2007-04-25, 02:21 PM
  5. Edit Scale list in AutoCAD LT 2008
    By greypaw in forum AutoCAD LT - General
    Last Post: 2007-04-06, 04:50 PM
