Results 1 to 7 of 7
Thread: Helpers...
    Revit Mararishi aaronrumple's Avatar
    2002-02
    St. Louis, MO
    4,695
    Default
    Laying out certian geometry has always been a little dificult in Revit. For instance: octagon bays. You need a lot of dimensions and ref. lines and then when you change your mind on the design you can't just scale the bay.
    I've made a series of helpers. Each helper is a geometric figure with an instanced parameter. Now I can just stretch it to the size I want. Then I can use the align tool to attach the walls in the right spot....
    Revit Guru gregcashen's Avatar
    2003-05
    Emeryville, CA
    1,352
    Default Re: Helpers...
    Your kindness is overwhelming...I had just this problem with an octagonal bay window.
    Thanks for the post!
    2003-05
    5,153
    Aaron,
    I just want to add my thanks also. Its people like yourself, willingly sharing information and tips, that make this forum such a great place.
    beegee
    2007-10
    Aaron,
    I am new to Augi so this might be a dumb question, but I don't see a link to the helpers that you made, can you point me in the right direction?
    All AUGI, all the time Elmo's Avatar
    2005-04
    South Africa
    959
    Nice idea Aaron. Never considered this an option.
    All AUGI, all the time clog boy's Avatar
    2006-12
    Probably near a PC.
    843
    Quote Originally Posted by brandon.149238 View Post
    Aaron,
    I suppose you need to make them yourself, unless someone is kind enough to post a few.
    Thanks for this tip.
    2003-04
    Chino, CA
    4,756
    Aaron,
    The original post by Aaron is from July of 2003....way back when AUGI Revit Forums were the Zoogdesign Forums. I think the links were lost over the transition. Maybe Aaron still has them and can report them.
