Thread: Creating a hole in a structural framing member.
    I could stop if I wanted to studio3p's Avatar
    2003-06
    Manitou Springs, Colorado
    257
    Default Creating a hole in a structural framing member.
    How do I go about creating a penetration through a structural framing member. I have an exposed double tee roof structure and I need to add skylights. The skylights work fine in the membrane and rigid roof that I created on top of the tees, but I haven't been able to make a hole in the tees.
    Thank you -
    AUGI Addict sfaust's Avatar
    2004-01
    Littleton, CO (Denver Metro)
    1,535
    Default Re: Creating a hole in a structural framing member.
    In place void I would guess...
    2001-12
    Irvine, CA
    7,567
    Unfortunately it isn't as simple as creating an in-place void. You'll need to add the holes to the "tees" in the family which means you'll need a separate family. This also means that you will have to determine the layout first and then build the voids into a specific tee family.
    Alternatively you could model the structure with a floor (or roof) slab and sweep the "tees" vertical members on the bottom of the slab. This will let you put floor (or roof) hosted objects into/onto them more easily.
    Lastly you could model the entire tee with an inplace family...
  1. Revit 2013 Structural Framing - Structural Usage Differences
    By a.bryant in forum Revit Structure - General
    Last Post: 2012-07-19, 10:47 PM
  2. Beam / Framing Member origin
    By djc1984 in forum Revit Architecture - General
    Last Post: 2010-09-08, 03:37 PM
  3. Replies: 1
    Last Post: 2009-04-23, 08:57 AM
  4. framing member joins
    By kathy71046 in forum Revit Structure - General
    Last Post: 2009-01-29, 05:29 AM
  5. 3D Framing Member Tool Palettes
    By cadkiller in forum ACA General
    Last Post: 2006-08-10, 04:42 PM
