Thread: Problem with linked file location
    2004-06
    Memphis TN area
    7,048
    Default Problem with linked file location
    I have a Revit MEP file linked into my file, and for some reason the Saved Path for that file will not update to the path where the file is saved on our server. The Local Alias shows the correct path, but the Saved Path still shows the path on the consultant's local server. It also seems like I have to reload the link every time I open the project.
    I also have a structural file linked in, and it works just fine. There is no Local Alias listed, but the Saved Path is the correct location.
    Any idea why my MEP Revit link is behaving this way?
    2006-06
    Toronto, ON
    2,386
    Default Re: Problem with linked file location
    Quote Originally Posted by patricks View Post
    Patrick,
    Is your linked Revit MEP file a local copy from a central file? I mean, if they sent you a local copy of their central file, the Saved Path will show the location of the central file and the Alias will show the location of the local file.
    Andre Carvalho
    NavisWorks Moderator david.kingham's Avatar
    2004-07
    Fort Collins, CO
    1,329
    Yeah I just had the same problem, open up their file and save it as a central on your server
    2004-06
    Memphis TN area
    7,048
    Thanks, that got it.
    I'm guessing the Structural file wasn't even in worksets since there were no problems with it.
    2006-06
    Toronto, ON
    2,386
    Or they've sent you their central file...
    Andre Carvalho
  1. Replies: 8
    Last Post: 2014-04-28, 07:43 PM
  2. Replies: 2
    Last Post: 2012-06-29, 06:07 AM
  3. Building file "place & location" doesn't match linked file?
    Last Post: 2010-11-08, 02:03 PM
  4. Problem exporting view with linked CAD file
    By myBIMhero in forum Revit - Plotting/Printing/Exporting
    Last Post: 2009-03-18, 09:09 PM
  5. Rendering problem with linked file
    By tim.101799 in forum Revit - Rendering
    Last Post: 2007-11-13, 08:23 AM
