Results 1 to 10 of 14
Thread: Division formula 1/3, 1/2, 2/3?
    The Silent Type CADMama's Avatar
    2016-01
    Where reference planes have Defines Origin checked
    1,040
    Default Division formula 1/3, 1/2, 2/3?
    I have a vertical division that I want to make an instance parameter with the option of the division being on either 1/3 or 1/2 or 2/3 the width of a window.
    I can get the 1/3 and the 1/2 but I just can't seem to get the 2/3 option.
    I have tried doing three yes/no parameters to select one bases on Steve Stafford's blog message on yes/no options. That did not seem to work for me.
    Any suggestions?
    Donnia Tabor-Hanson
    AUGI Mom
    GO Vols!
    "I'm not bad. I'm just drawn that way."
    AUGI Addict jsteinhauer's Avatar
    2015-11
    Madison, WI
    1,317
    Default Re: Division formula 1/3, 1/2, 2/3?
    Quote Originally Posted by CADMama View Post
    Any suggestions?
    Hi Donnia,
    I'm having a hard time picturing what you are trying to do. But, my first thought would be formula's don't like instances imbedded into them. Second, would using an array be more benefical to your efforts? Could you please post the family you're working on, so we can see it first hand?
    Jeff S.
    2016-01
    1,040
    I want to vertical division to either be 1/3 the width from the left, half way, or else 2/3 the width from the left.
    I am developing this for a class that I am to teach. I don't have the geometry in here yet - still working on the reference planes and formulas.
    Let me know if you have any questions after looking at my family and formulas.
    Donnia Tabor-Hanson
    AUGI Mom
    GO Vols!
    2015-11
    Madison, WI
    1,317
    I could be wronge, but doesn't yes/no only allow you to be either 0 or 1? This only would allow you two choices. Would it be better to use an index? Let me do some more digging for you...
    I'll post what I find hopefully soon.
    Jeff S.
    2001-12
    Irvine, CA
    7,567
    Well this is one way...I suppose...
    2015-11
    Madison, WI
    1,317
    Smile Re: Division formula 1/3, 1/2, 2/3?
    Quote Originally Posted by Steve_Stafford View Post
    Steve you Rock!!!
    I was along the similar lines, but I couldn't get the formula to work. Is there a Tutorial out there that goes over proper formula creation?
    if(Index Vert Div = 1, "((Width/1')/3)", if(Index Vert Div = 2, "((Width/1') / 2)", if(Index Vert Div = 3, "((Width/1')*(1/3)")))
    Thanks again Steve, I'll be referencing this family often.
    Jeff S.
    2001-12
    Irvine, CA
    7,567
    It is sort a kind a like LISP...lost in stupid parenthesis. The help file does explain the syntax, pretty well...you be the judge. I've managed with that info. I've attached another version, same technique except I did the "math" in separate fixed parameters so I could use plainer English in the long formula.
    Edit: fixed the math...
    2016-01
    1,040
    That was it - almost.
    I changed the formula to this
    if(Vertical Divisions = 1, (Width / 3), if(Vertical Divisions = 2, (Width / 2), if(Vertical Divisions = 3, (Width / 3) * 2, Width)))
    That gave me the 2/3 division.
    Donnia Tabor-Hanson
    AUGI Mom
    GO Vols!
    2001-12
    Irvine, CA
    7,567
    haha...no wonder my bank account never balances fixed the attachments and image file.
    2016-01
    1,040
    OK - question about the integer parameter - can you set a max and a min?
    If I try to go above what the forumla using that parameter uses - or below for that matter - it gives me an error. Is there some what to lock it to just the 1,2, or 3 integers?
    Donnia Tabor-Hanson
    AUGI Mom
    GO Vols!
  1. I wish I could group keynotes by division
    Last Post: 2010-03-12, 05:57 AM
  2. MasterFormat 16 Division vs. 2004
    By christo4robin in forum Revit - In Practice
    Last Post: 2006-05-02, 02:30 PM
  3. Division of Labor
    By bbacker in forum ACA General
    Last Post: 2005-05-13, 04:28 PM
  4. Curtainwall Division Question
    By pashley in forum Revit Architecture - General
    Last Post: 2005-04-04, 03:54 PM
  5. Room division lines
    By Wagurto in forum Revit Architecture - General
    Last Post: 2004-10-13, 03:08 PM
