Results 1 to 8 of 8
Thread: Difference between Viz / Viz Render?
    2004-02
    54
    Default Difference between Viz / Viz Render?
    Is there a difference between Autodesk Viz and Viz Render that ships with ADT 2005? I have Viz Render and wanted to do a few of the tutorials from the Autodesk website but there seems to be something different. If the two are completely different, does anyone know where I could get a few online tutorials for Viz Render?
    Thanks.
    2015-12
    Arizona
    2,337
    Default Re: Difference between Viz / Viz Render?
    The biggest difference...VIZ is a full-on modeling
    and animation program. VIZ will allow one to
    render across the network, Viz Render will not.
    2004-02
    54
    Thanks Michael,
    I'm also seeing that there must be a lot of rendering options missing too, such as mental ray materials.
    2015-12
    Arizona
    2,337
    The idea here is simple
    IF Viz Render as implemented in
    ADT 2005 were fully functional
    one would have no motivation
    to purchase VIZ.
    26
    A good place to start looking for Viz Render online tutorials is www.vizdepot.com. They are a good source of information on both the full version of Viz and ADT Viz Render. Also, I know there were several Viz Render tutorials that shipped with ADT 2004 and automatically loaded into the Tutorials folder under ADT. I noticed they are missing in ADT 2005. If you know anyone that has ADT 2004 installed on their machine, just copy the tutorials folder (it's about 200MB worth of files). Also, Any Viz tutorials that deal with photometric lighting and radiosity will also work in Viz Render.
    2004-02
    54
    I checked out that web site. Thanks, it has some very useful info and I think I'll try the tutorials.
    2003-03
    Brenham, Texas
    74
    I also think that you can not construct shapes in VIZ render.
    You have to do all the drawing in ACAD.
    2015-12
    Arizona
    2,337
    I am seeing a huge difference in the tools one has for creating
    materials within Viz Render as compared to the real version.
    And these are not to my liking either, instead of being able to
    to create good materials proceduraly one must resort to mapping
    images instead simply because the material editor has been
    dumbed down.
  1. Network render with the Scanline render engine
    By Steve_Bennett in forum DV - Tips & Tricks
    Last Post: 2012-04-19, 03:09 AM
  2. What's the difference
    By Tharwat in forum AutoLISP
    Last Post: 2010-09-09, 08:48 AM
  3. Render Revit Model with new Twilight Render Engine
    By FletchMT in forum Revit - Rendering
    Last Post: 2009-09-18, 07:48 PM
  4. render model and cant see it in the render window
    By sherflor in forum ACA General
    Last Post: 2009-07-17, 11:19 PM
  5. Replies: 1
    Last Post: 2008-09-18, 01:15 PM
