Results 1 to 8 of 8
Thread: Can you lock views so they can't be deleted???
    2006-02
    89
    Default Can you lock views so they can't be deleted???
    Is there a way to be able to 'lock' views so that they can't be deleted???
    I am aware of the pin objects button, but this doesn't stop them being deleted.
    I have a feeling the answer is no, and it is a matter of the user being aware of this, but thought I would ask the question anyway.
    Thanks for you help in advance
    100 Club Brian Benton's Avatar
    2015-06
    at home
    183
    Default Re: Can you lock views so they can't be deleted???
    If you have the view in a viewport, lock the viewport, and put the viewport on a particular layer and lock that layer. The viewport won't be deleted, or moved, etc. Maybe this will help? I know a viewport isn't a view.
    2006-06
    Toronto, ON
    2,386
    Quote Originally Posted by bbenton.91765 View Post
    You can't do that in Revit. There's no layers in Revit. You are probably talking about AutoCAD.
    Andre Carvalho
    2006-02
    89
    Yes, when reading bbenton.91765 reply, I thought that it sounded much like an Autocad locking layers.
    Andre, this is what I suspected thought, that you can't lock the viewport & that it is more of a user be-aware type situation.
    Thanks for your help
    I could stop if I wanted to mruehr's Avatar
    2004-01
    Perth
    223
    well you can if you are working with worksets
    you can assign a vieworkset to a imaginary user (BIM Leader) and make it editable
    so it will be lockt till the user makes it noneditable again
    2006-02
    89
    I have thought about that option as well, but one of the post I read suggested not using worksets like this, as that is not how they were designed to be used.
    I understand what your saying and it is a good suggestion, but I now think it should be more about the user being more careful about what they delete and not due to the parametric nature of Revit.
    MRuehr what are your thoughts on that?
    2004-01
    Perth
    223
    well true but we are human, how many times have i moved a camera View in a moment
    off guard. i agree with the notions work-sets should not be used for visibility controls.
    but assigning views to users is often useful particularly when annotating .
    as well recommended practice. so one more step and locking them to a user seems save for me. we do it for grids why not for special views?
    2006-02
    89
    Thumbs up Re: Can you lock views so they can't be deleted???
    Thanks for your thoughts on that. You certainly have a couple of good points there to consider for the next job that is being setup with worksets.
    I must admit that I agree with you about having a seperate workset for grids and levels, so why not for specialised views.
  1. Ability to Lock Views in Revit
    By john.coelho in forum Revit Structure - General
    Last Post: 2019-08-24, 12:33 AM
  2. Restore deleted views from backup...
    By FWSchreck in forum Revit Architecture - General
    Last Post: 2018-02-03, 04:04 PM
  3. 2014: Lock views on layout tabs / paperspace
    By themuleman in forum AutoCAD Structural Detailing
    Last Post: 2014-02-16, 07:58 PM
  4. How do you stop the tags on elevations and views from being accidently deleted
    By speedfreak5150 in forum Revit Architecture - General
    Last Post: 2010-06-08, 03:58 AM
  5. Lock Views
    By chippy in forum Revit - Platform
    Last Post: 2008-03-21, 04:52 PM
