Thread: Dwgprops, and vlax functions
    2004-02
    60
    Default Dwgprops, and vlax functions
    I am trying to write a lisp routine that needs to call the comments found under dwgprops. I know that this is able to be accessed via vba and resides at ThisDrawing.Acad.AcadSummaryInfo.Comments.
    Here is what I thought might work
    (vl-load-com)
    (setq #whatever (vlax-get-properties ThisDrawing.Acad.AcadSummaryInfo.Comments))
    This obviously is not the right syntax, mostly because it didn't work
    Anyhelp would be greatly appreciated as always,
    Jason Self
    P.S. If this double posts I am sorry, I couldn't find what I though I had posted this morning and figured that I didn't actually submit it.
    126
    Default Re: Dwgprops, and vlax functions
    In lisp, it's a multistage task to query objects as it doesn't use the dot syntax that VBA uses. These steps will get you to the Comments property:
    (setq acad_app (vlax-get-acad-object)
          activeDoc (vla-get-activeDocument acad_app)
          dwgProps (vla-get-summaryInfo activeDoc)
          comments (vla-get-comments dwgprops)
  1. Replies: 0
    Last Post: 2012-11-24, 07:38 PM
  2. vlax-curve-... functions
    By David.Hoole in forum AutoLISP
    Last Post: 2009-07-17, 10:05 AM
  3. dwgprops dictionary
    By dnovak.90006 in forum AutoLISP
    Last Post: 2007-08-22, 12:50 PM
  4. DWGPROPS command
    By elowe494 in forum AutoLISP
    Last Post: 2006-01-05, 10:12 PM
