Thread: Adjusting an Aerial Image Material
    100 Club jason.combs's Avatar
    2005-08
    St. Louis, MO
    173
    Default Adjusting an Aerial Image Material
    I have a terrain object in a Viz model. I have an aerial image that I want to map to the terrain. My image is larger than the terrain model. When I place the aerial image on the terrain model the image is not centered correctly. What should I do to adjust the material map to properly center it on the terrain model?
    Thanks in advance,
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,730
    Default Re: Adjusting an Aerial Image Material
    First, set your tiling for the image to 1.
    Then select the object with the image applied to it. If it doesn't already have a UVW Map applied to it, do so now and set the tiling settings to match the material. Then in the modifier stack expand the UVW modifier and select the gizmo and then in the drawing window move it until the image aligns to the desired location.
    Or just use photoshop (or similar program) to adjust the image to match the terrain.
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
  1. 2013 Applying aerial image base in timeliner NW crashes.
    By jobwallis724305 in forum NavisWorks - General
    Last Post: 2013-11-12, 05:03 PM
  2. 2013: Material Image and Transparency Image Not Aligning
    By KiLO in forum Revit - Rendering
    Last Post: 2013-08-23, 09:52 PM
  3. 2013: Aerial image used as decal obscuring model
    By gregb in forum Revit Architecture - General
    Last Post: 2013-02-11, 03:44 PM
  4. Aerial Image in print view only
    By pfindlan in forum Revit - Platform
    Last Post: 2008-03-11, 06:49 PM
  5. RD 2008 Aerial Image Anomalies
    By Spokes in forum Raster Design - General
    Last Post: 2008-02-08, 08:51 PM
