I'm having trouble w/ a custom mass element that I'm using for an ornamental column in ADT '06. The display settings work fine in the plan/med-detail config - in display properties, I've turned the disp component "above cut plane" to off & am using a solid hatch at the cut plane. Works like a charm.
However, when I switch to reflected, where I only want to see the upper portion (capital) of the column, the entire column is still visible. The "above/below cut plane" disp config options are no longer available - just "entity."
The cut plane is set in the middle of the column, and the above/below display range in the Display Manager seem to have no affect on the mass element when I change them.
Is there some way to add display config options like "above/below cut plane" in the display properties? Or am I going about this the wrong way completely? The mass element columns have worked very well for everything else so far - are they just not intended for use w/ reflected clng plans? Any insight would be greatly appreciated.
