Results 1 to 10 of 12
Thread: Section view in a section view
    Blue Springs, MO
    658
    Default Section view in a section view
    I have a section cut vertially through a concrete column and I need another section cut horizontally through the column. Has anyone figured out how to do this yet. I was able to just make another plan view and adjust the view range and crop region to get the detail I needed but I can't get an actual section cut to work properly in the section. Any ideas?
    2006-06
    Toronto, ON
    2,386
    Default Re: Section view in a section view
    Just create a new section into the section view and then rotate the section just created to have it horizontal.
    Regards,
    Andre Carvalho
    2005-07
    3,250
    Or select a "Detail" section, which allows you to place it horizontally.
    Blue Springs, MO
    658
    Quote Originally Posted by dbaldacchino View Post
    Detail section? You mean a callout? I'm cornfused.
    Blue Springs, MO
    658
    Quote Originally Posted by Andre Carvalho View Post
    Regards,
    Andre Carvalho
    Why do the simplest solutions seem to be the hardest to find. I had a little trouble finding the thing after I rotated it but a little playing with the crop region and I got what I needed.
    THANKS!!!
    2005-07
    3,250
    In your original section view, select the section tool. Now on the type selector, select "Detail View: Detail". A section can now be placed at any angle. If it is parallel to a floor plan view and within it's view range, a detail callout will also show up.
    Blue Springs, MO
    658
    SWEET!!! I really need to go through those new features workshops. I don't recall that being there in earlier releases.
    2005-07
    3,250
    Actually, it's been there since I started using Revit in 8.0
    Blue Springs, MO
    658
    I need to talk to our trainer then. We started in RS2 and our trainer didn't show us that one. Good to know it's there. Actually surprised I haven't needed it before now.
    AUGI Addict luigi's Avatar
    2015-11
    Royal oak, Michigan
    1,513
    At least your trainer didn't tell you that to have more or less than 42 breakers in an electrical panel would probably cost $100,000...
    Quote Originally Posted by jmctamney View Post
  1. Hatch Scale of Detail View Created from a Section View
    Last Post: 2014-02-25, 11:58 AM
  2. I wish I could open a section/drafting view by double clicking on it in the sheet view
    By Wish List System in forum Revit Structure - Wish List
    Last Post: 2013-11-02, 11:42 PM
  3. 2010: Copy a section view from the model to a drafting view.
    By Giorgos82 in forum Revit Structure - General
    Last Post: 2013-03-18, 02:14 PM
  4. Replies: 0
    Last Post: 2011-11-02, 08:04 PM
  5. Section Views and Section View Groups
    By WScottAllenPE in forum AutoCAD Civil 3D - Sections
    Last Post: 2010-07-28, 03:25 PM
