Thread: weird revit Revit crash after external application is done running
    2008-02
    New York
    81
    Default weird revit Revit crash after external application is done running
    I have recently encountered this error while trying one of my programs on other people's computers. (running the same program on my machine works fine)
    Also, on a new program that I just wrote, this time it happens on my computer, upon closing the form.
    code is written in Visual C#. My guess is the proble lies with some faulty references, but the error message has no useful information:
    "A fatal error has occurred. The application will be terminated. You will be given the opportunity to save recovery files for all of your changed projects. Would you like to save a recovery file for Project1?"
    The message box gives me the option to save and exit or juste exit and then revit closes and it prompts me to send out an error report.
    Has anyone seen this?
    Thanks
    2015-10
    Escondido, CA
    91
    Default Re: weird revit Revit crash after external application is done running
    Do you or the other computers have other external applications installed? I had the same problem with a Revit add-in on one of my menu items if it was the 10th external application menu item. So on my machine it was fine, but on another machine that had Revit Extensions installed before my add-in, it would crash. All of my code would run successfully, but right after it returned control to Revit Structure, it crashed.
    You may have encountered the same problem. It is supposed to be fixed in RST 2009, although I haven't had a chance to test it.
    2008-02
    New York
    81
    Smile Re: weird revit Revit crash after external application is done running
    It works now,thank you!
  1. Revit can't run the external application
    By oakam430373 in forum Revit Architecture - General
    Last Post: 2014-10-21, 08:25 PM
  2. External application - open Document
    By kv in forum Revit - API
    Last Post: 2010-11-02, 08:05 PM
  3. cant display a menu as external application
    By andresvite in forum Revit - API
    Last Post: 2009-03-20, 09:15 PM
  4. Replies: 3
    Last Post: 2008-07-09, 02:51 AM
  5. Edit MText when using an external application
    By ruthellenwilliams in forum AutoCAD General
    Last Post: 2006-03-07, 06:06 PM
