Thread: REORDER CONSTRUCTS AND VIEWS IN PROJECT NAVIGATOR
    2008-01
    27
    Default REORDER CONSTRUCTS AND VIEWS IN PROJECT NAVIGATOR
    Is there a wayto reorder constructs and views in Project Navigator? I am creating a very large template and I would like to order the various constructs alphabetically so that I can locate them easily. When I add a construct to a category, it is listed at the end so I might have a,c, f,h,m then add e,g,l. If I have 20 constructs, I might spend a lot of time locating the correct construct that I want to work with.
    Thanks for any help you might throw my way.
    Mark
    2006-12
    Big "D"
    3,711
    Default Re: REORDER CONSTRUCTS AND VIEWS IN PROJECT NAVIGATOR
    Mark,
    Welcome to AUGI and congrats on your first post.
    To get your constructs, elements, and views in alphabetical order, just hit the refresh button at the bottom of PN. You may need to do it for each tab (construct, then view), I've never noticed if one refresh takes care of both tabs, but it probably does. PN will put everthing in alphabetical order automatically.
    For your sheets, you can drag and drop them in any order you want.
  1. Replies: 1
    Last Post: 2013-03-24, 07:39 AM
  2. Reorder Named Views
    Last Post: 2010-09-14, 12:42 PM
  3. Project Navigator Constructs Problem
    By drafting1 in forum ACA General
    Last Post: 2008-01-18, 11:10 AM
  4. Tip on dragging views into sheets in Project Navigator
    By stelthorst in forum ACA/AMEP Tips & Tricks
    Last Post: 2007-07-13, 10:46 PM
  5. Replies: 2
    Last Post: 2007-05-20, 04:05 PM
