Thread: Brick courses in elevations
    2006-12
    Big "D"
    3,711
    Default Brick courses in elevations
    Our buildings are brick with a base, field, and accent stripes. Here's the question:
    I've always taken the time to create a wall style with each accent stripe, then field, then accent, then field, etc. etc. Since I'm not doing renderings anymore, is there a better way to show the brick coursing on my elevations? Should I just create the elevation and do a pline with a thickness for the accent stripe, or would it be better to create the wall style like it should be and edit the hatch lineweights to show the accent brick? Is there another way to do it?
    2002-09
    Madison, WI
    5,687
    Default Re: Brick courses in elevations
    What we've done is create a "shaded" pen and apply a solid hatch pattern over the top to make them stick out. Then we key note each one. We also label them in the wall sections.
    2006-12
    Big "D"
    3,711
    Quote Originally Posted by david_peterson View Post
    So you just do that in the elevations right? It would save a lot of work not having to create every accent band. Thanks David.
    2002-09
    Madison, WI
    5,687
    Well that was one way I've seen it done. On another project I've seem them only show the corse lines that were the accent strip brick and a thicker line for the control joint. The field brick pattern wasn't shown. They would just key note the area.
  1. Model each brick on a brick wall
    By AP23 in forum Revit Architecture - General
    Last Post: 2010-06-18, 03:05 PM
  2. Replies: 5
    Last Post: 2008-12-02, 01:00 PM
  3. Brick Corbel - doesnt line courses up
    By still.james in forum Revit Architecture - General
    Last Post: 2008-02-27, 01:52 AM
  4. Why do we put brick pattern in elevations
    By aretap in forum Revit - In Practice
    Last Post: 2007-11-04, 02:29 PM
  5. Replies: 3
    Last Post: 2007-03-20, 04:25 PM
