Here is one with the option to select from preset slopes or stretch either leg to custom lengths in 1/8th inch increments. It is also flippable.
Fields are used so remember to update them for an accurate display.
Works good. I really gotta figure out how to use the lookup parameter.
BTW the file you posted is a block called "Slope - dyn" with a block inside of it called "Slope - dyn" also so you get an error on insert for the block "referencing itself". Of course it works fine if you simply open the original file. I didn't know if this was your intention or not. If people see the error they might give up and you can't share the wealth!
