Thread: Dimensions acting funny
    2007-06
    43
    Default Dimensions acting funny
    Has anyone had this problem. If so, can it be fixed. Notice the dimension lines to the right only start after it crosses the crop extents. However, the left side and bottom seem to work fine.
    All AUGI, all the time jmctamney's Avatar
    Blue Springs, MO
    658
    Default Re: Dimensions acting funny
    I've noticed this before. Don't know what causes it. I just stretch the extension lines back. Also...did you notice that the extension lines don't extend past dimension line when this happens?
    I've just chaulked it up to Revit quirks I don't understand. I just find a workaround and move on.
  1. Aligned dimensions acting like linear dimensions (only up-down, left-right on page as viewed)
    By browns.joseph308864 in forum Revit Architecture - General
    Last Post: 2011-12-07, 01:48 AM
  2. xref's acting funny
    By rhayes.99001 in forum ACA General
    Last Post: 2008-05-07, 07:08 PM
  3. Dashboard acting funny
    By lonewolfjustin in forum AutoCAD General
    Last Post: 2008-03-12, 12:39 PM
  4. XREF command acting funny
    By akasten in forum AutoCAD General
    Last Post: 2005-11-17, 11:15 PM
  5. Object Tracking Acting Funny
    By arcadia_x27 in forum ACA General
    Last Post: 2005-06-14, 04:19 PM
