Thread: compaibility issue of autocad architecture 2008 with vista
    2006-04
    Default Compatibility issue of AutoCAD architecture 2008 with vista wins
    I am having a hard time in installing ACA2008 onto vista windows OP SYS; the installation is smooth till I run ACA2008 and find out that @ properties palette the style does not appear and all objects re walls, mass elements are specified as AEC_WALL or AEC_MASS _ELEM with NO indications to style.
    Moreover, in the PROPERTIES palette, the DESIGN subfolder is minimized to "General" and "3d Visualization" tabs the rest is either shaded or nonexistent.
    Keep in mind that walls&mass elements are usually set as WALL and MASS ELEMENT in PROPERTIES palette and the Tabs in each are much more in subdivisions.
    I'd appreciate any help to resolve this problem.
    2006-12
    Big "D"
    3,711
    Default Re: compaibility issue of autocad architecture 2008 with vista
    Welcome to AUGI and congrats on your first post.
    Well, I ran ACA2008 on Vista for a short time, and now I'm running ACA2009 on Vista and I've not had that problem. I'd suggest doing a repair, or even a clean reinstall. Have your tried either yet?
    2002-09
    Madison, WI
    5,688
    What kind of hardware are you using? ie box config.
  1. Replies: 15
    Last Post: 2010-09-23, 01:57 PM
  2. Revit 2008 on Vista 64 Activation issue.
    By Les Therrien in forum Revit Architecture - General
    Last Post: 2009-04-02, 11:32 PM
  3. Revit Architecture 2008 Serial Issue
    By Overconstrained in forum Revit - In Practice
    Last Post: 2008-01-21, 04:19 PM
  4. Vista Support for AutoCAD 2008 (and 2007)
    By eric.stover in forum AutoCAD General
    Last Post: 2007-05-09, 05:05 AM
