Thread: ACA (ADT) object Import
    2003-03
    Default ACA (ADT) object Import
    Our office currently uses ACA 2008. We manage several buildings at a world headquarters campus. Several of these buildings were built many years ago and over time have been input into AutoCAD in various forms. We are in the process of developing a CAD standard to bring all the floor plans of each building up to. At some point in the future we will most likely be moving over to Revit within 12 to 18 months, hopefully. I am concerned about the standard we are now developing and how the drawings will translate into Revit. We are planning on using basic ACA walls, windows, doors, etc. we will not be delving deeply into the capabilities of ACA and customizing a lot of stuff. At this point how well does ACA objects, walls, windows, doors, etc. translate into Revit? Also, any semi solid ideas about how this would work in the future would be greatly appreciated.
    AUGI Addict jeffh's Avatar
    2002-09
    Manchester, NH
    1,087
    Default Re: ACA (ADT) object Import
    This is possible using IFC exports from ACA and import IFC into Revit. There is likly going to be some translation issues from one to the other. Attached is a VERY simple example of using IFC to go from ACA to Revit. The objects in the Revit project were all created in ACA and then exported to IFC. That IFC file was imported into Revit.
  1. Import AutoCAD Map3D Object Data
    By Wish List System in forum NavisWorks - Wish List
    Last Post: 2014-11-13, 06:00 PM
  2. 2013: Import shapes and attached data (shapefile, object data etc) to Revit
    By cooperch663326 in forum Revit Architecture - General
    Last Post: 2014-06-02, 10:53 AM
  3. 2013: "Import detected no valid elements in the file's paper space. Do you want to import from the model space?
    By thomasmerrittgibson397439 in forum Revit Architecture - General
    Last Post: 2013-07-05, 06:53 PM
  4. Replies: 1
    Last Post: 2012-07-09, 03:09 PM
  5. Problem about object data value (import from DGN file)
    By supphachai.s in forum AutoCAD Map 3D - General
    Last Post: 2009-02-16, 04:36 AM
