Results 1 to 1 of 1
Thread: Window Assembly HELP!!!
    2006-12
    Big "D"
    3,711
    Default Window Assembly HELP!!!
    Okay cad geniuses, I can't figure out how to make the following window. It's a raked window, with divided lights on one side and the top. I know it can be done with a door / window assembly, but I don't have a clue how. My attempts aren't even coming close. Can someone first, whip this out for me, then second, give me some insight as to how you did it?? I also tried using a profile, but only the frame came out, the window was just a huge peice of glass.
    Oh yea, I'm using ACA2009. Thanks in advance!
    Dab Nabbit!!!! I'm in the wrong forum. I coulda swore I was in the ACA side of things. Ummmm, Mr. Moderator, can you move this Puh-leaz!!! Thanks.
    Why is it called common sense when it is so rare?
    RevitForum.org
  1. Editing Window Assembly
    By michelle.264065 in forum ACA General
    Last Post: 2010-10-01, 12:39 AM
  2. Door/Window Assembly
    By leothebuilder in forum ACA General
    Last Post: 2007-11-29, 11:45 PM
  3. Window Assembly help!
    By BCrouse in forum Style Management
    Last Post: 2005-05-25, 11:35 AM
  4. Door/Window Assembly
    By swaink in forum ACA General
    Last Post: 2004-12-21, 04:10 PM
  5. Twin Window Assembly
    By jhohman in forum Style Management
    Last Post: 2004-11-02, 06:21 PM
