Steve_Stafford
A couple more thoughts. Assuming the link connector deal worked. Have you tried connecting the mechanical equipment to the hydronic system before connecting any of the mechanical connectors in the project. In other words, connect the hydronic system first, then the mechanical system.
What are you connecting this "ME" to? You might need to create the hydronic system with a down or upstream component and then add the "ME" to that system using Add Equipment. In a quick mockup I was able to do this and have both connectors consider themselves part of the same Hydronic system...the pipes thought they were too through "guilt by association".
Can you post the "ME" (mechanical equipment) here so we can try it with the actual culprit...and maybe Kyle can too?
