BIGDIG641
i set solidhist to 0 but still have the same problem.
when i subtract the 2-3D solids the resulting object does not behave like the original primitive in the fact that the gips are gone. one grip though, does appear off of the object in near by space.
do you know of a way to trim studs, birdsmouths and eaves from a rotated 3D rafter used as a gable end?
there was a nice command under boolean called trim by section/plane i believe, i used in ADT 2006 which i can't find in ACAD 2008. is there something similar?
thanks
HG
