Thread: stretching with a fence
    2008-04
    CDA Idaho
    Default stretching with a fence
    am i doing something wrong? when i attemp to use a fence to stretch many different points at once, the fence only grabs a few points within, does 2007 adt do this command?
    thanks
    Certifiable AUGI Addict
    2015-11
    Jo'burg SA
    4,512
    Default Re: stretching with a fence
    Not entirely sure what you mean. If I use fence selection with the stretch command, it actually performs a move. Are you trying to get the fence on the exact end-point? It's still going to just move the entities.
    The thing about stretch is you need a closed crossing selection - every point inside the selection is stretched, while every entity falling totally inside (or selected differently) is moved. The only 2 methods of selection which makes stretch behave properly is Crossing (the normal rectangle selection to the left) and CPolygon (which I think would work like you want), Fence doesn't close the selection "polyline" so there's no points "inside" the selection. So instead of typing F for fence, type CP for "Closed Polygon".
    2003-10
    706
    Quote Originally Posted by irneb View Post
    ... and by "points" you mean everything that would have a grip if highlighted right?
    2015-11
    Jo'burg SA
    4,512
    Quote Originally Posted by Coolmo View Post
    Yes, e.g. endpoints of lines / arcs. See the attached screen captures of what I mean.
    0,0,0 The Origin
    8,570
    Simply put - to Stretch, you must show acad that some control points will be affected and that others will not be affected - like one end of a line versus the other end. You can only do this with a closed selection that includes the points to be moved and excludes the other points - like IRNEB said. In separating the selected and not-selected points your selection method will naturally cross the objects involved.
  1. Zoom while stretching
    Last Post: 2012-05-23, 10:01 PM
  2. Fence - LISP to pick a pre determined fence line?
    By EngME in forum AutoCAD General
    Last Post: 2011-10-31, 08:21 PM
  3. Fence?
    By wbenatti in forum Revit - Platform
    Last Post: 2009-02-10, 11:00 AM
  4. block stretching and the arrow that does the stretching
    By .chad in forum Dynamic Blocks - Technical
    Last Post: 2008-09-03, 09:39 PM
  5. FENCE ??
    By shaunamorain in forum Revit Architecture - General
    Last Post: 2007-01-12, 04:54 PM
