Thread: EDIT MVPART
    2007-09
    36
    Default EDIT MVPART
    I inserted a 24x4 sidewall grille into my plan, I then went to modify the height and the CFM and the only parts that were listed under the part size was the 6x4; 6x6; and the 8x6.
    Has this happend to anyone else, if I go to insert a new one I have the full part list in the dialog box. Any help would be greatly appreciated.
    2008-02
    6
    Default Re: EDIT MVPART
    In the Multi-view Part Modify window there is a Limit Search to: field. If this number is set too low, all the available sizes will not display. Hope this helps.
    2007-09
    36
    Cholbert,
    Thanks, that was it, I didn't even think of looking at that. I could have sworn I had it set to 20 which is the default. Thanks a lot.
    2006-02
    424
    Talking Re: EDIT MVPART
    You all have just made my day!!!
    I'm working in ABS07 and had created 6 new parts. For some reason, I could only see 2 of the new parts. Very annoying/furstrating!
    When I read this I rushed over and tested it out and sure enough my other parts show up now! WAHOO!
    Now I've gotta figure out if it is a computer by computer setting, a profile setting, and/or something that has to be set for every part or something crazy like that.
    I don't do beer, but here's a Dr. Pepper for ya!!
  1. Classification MvPart
    By bast.jean380633 in forum ACA General
    Last Post: 2013-11-22, 03:11 PM
  2. MVPart visibility
    By Gaz62 in forum AMEP General
    Last Post: 2009-11-05, 08:17 PM
  3. MVPart Display Help!
    By kwanjuju in forum AMEP General
    Last Post: 2008-05-09, 06:34 PM
  4. mvpart add Delay
    By buzz in forum AMEP General
    Last Post: 2008-02-04, 09:51 PM
  5. Can you create/edit your own MVPART?
    By CADMama in forum Parts Builder
    Last Post: 2006-08-11, 06:07 PM
