Page 1 of 5 12345 LastLast
Results 1 to 10 of 46
Thread: Page Setup Manager
    2002-12
    14
    Question Page Setup Manager
    Does anyone know of a way to set-up multiple layouts with the same page set-up simultaneously?
    Thanks.
    Peter
    9,805
    Default Re: Page Setup Manager
    Do you mean to "apply" a page setup to multiple layouts?
    If so, are you wanting to do this within the AutoCAD UI, or with lisp/VBA code?
    2002-12
    14
    Yes, that is exactly what I am trying to do. As to whether or not it is through the AutoCAD Ui or through lisp/VBA, it doesn't really matter.
    Thanks.
    Peter
    2007-10
    Orlando, FL
    118
    I use ADT2006, so I don't know if they have added the feature.
    I do know that DWGTrueView will do that. You can convert in place and just leave the file the same, but import and apply plot styles to layouts.
    You could do hundreds of files in one go this way.
    2004-10
    Scotland
    102
    This is exactly the problem I'm trying to solve.
    You can use a macro to set filedia to 0, & use -PSETUPIN to insert a standard print setup, but I'm stumped as to how to assign the setup to a layout without assigning it manually through PAGESETUP.
    If solution is known which doesn't use LISP, etc., all the better, as I'd like to share this with LT users.
    Last edited by andersonjg; 2008-05-21 at 09:50 AM. Reason: Can this thread please be moved to the AutoCAD plotting section?
    6,418
    You can use PUBLISH. Select all the sheets and then select a setup. This doesn't apply the setup permanently, but it works for plotting. Other than that, I only know of programatic ways to do it. I have a page setup import vba solution on the Exchange that does it.
    LinkedIn
    2015-11
    Jo'burg SA
    4,512
    Here's another I've created for myself using LISP. It's command line only - so you can run it through a script on multiple drawings. Just have to make sure the setup is loaded in each DWG first as with -PSETUPIN.
    The command is -MPageSetup. I'm in the process of adding a dialog interface, that's why the - prefix for command line version. But for your scenario, I think it's not necessary. It asks for the tabs to assign it to (or * for all), then it asks for the Setup Name.
    2004-10
    Scotland
    102
    Irneb,
    Thanks for sharing the LISP, the routine works perfectly.
    2005-01
    58
    Thanks for that lisp routine. I have been thinking that this is one routine I really would have liked and now I have it.
    Thanks again.
    2015-11
    Jo'burg SA
    4,512
    You're both welcome ... BTW I've finished the dialog interface (attached).
  1. Page Setup Manager Dialog
    Last Post: 2009-10-13, 04:53 AM
  2. page setup manager SLOW
    By cr_gixxer in forum ACA General
    Last Post: 2009-05-08, 10:05 PM
  3. Enhancement to Page Setup Manager
    Last Post: 2006-02-13, 05:08 PM
  4. Add Plot Stamp to Page Setup Manager
    Last Post: 2006-01-15, 05:25 AM
  5. Page Setup Manager
    By ejohnson.73328 in forum AutoCAD General
    Last Post: 2004-08-27, 02:13 PM
