Thread: Spaces not bounding
    Revit MEP Moderator mjdanowski's Avatar
    2007-03
    890
    Default Spaces not bounding
    For some reason, in a new project we started up in 2009, the spaces are not being vertically bound by ceilings. The linked model is room bounding, however if I set the upper limit to 3000' or something, it will go to 3000'.
    Isn't it supposed to be caught by the ceiling and hug whatever "bounds" it vertically?
    Matthew Danowski, PE, LEED AP BD+C
    Project Electrical Engineer
    Baltimore, MD
    All AUGI, all the time kyle.bernhardt's Avatar
    2005-10
    Inside the Factory
    705
    Default Re: Spaces not bounding
    Quote Originally Posted by mjdanowski View Post
    Matt,
    It most certainly should be behaving that way. Since the Linked Model is already set to be Room Bounding, I'm not sure what's going on. Perhaps the Ceiling Elements themselves are not set to be Room Bounding in the Architectural Model?
    HTH,
    Kyle B
    2007-03
    890
    Randomly found out how to fix this....
    If you do not have "Calculate Areas and Volumes" set in your settings, it will not bound the room by the ceiling.
    I do not know if this is intentional or not, but that seems to be what happens.
    Baltimore, MD
    2005-10
    Inside the Factory
    705
    This is exactly how it is designed to work. With that setting turned off, we only manage the areas that you see in a plan view. This can have a significant performance improvement to a large project, but we will not be maintaining what elements are located in what volumes, and the analytical calculations that go along with that location.
    Cheers,
    Kyle B
  1. Spaces to cope with vertically irregular spaces better
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2015-12-05, 08:10 PM
  2. Bounding Box LOD's
    Last Post: 2013-11-16, 03:38 AM
  3. Room Bounding Walls NOT Bounding Rooms??
    By jkady in forum Revit Architecture - General
    Last Post: 2009-09-30, 04:57 PM
  4. How to fix non bounding rooms?!
    By Beancud in forum Revit MEP - General
    Last Post: 2009-08-05, 11:16 AM
  5. How to set one Bounding box to another Bounding box
    By basha_sk312 in forum VBA/COM Interop
    Last Post: 2006-02-03, 04:07 PM
