Thread: Huge time for processing when dealing with Annotative scale
    2006-03
    Originaly from Egypt located in Qatar
    10
    Unhappy Huge time for processing when dealing with Annotative scale
    Dear All,
    I am trying to deal with ACA 2008/2009 and solve this problem for a week now. It is causing all of the Engineers working here to be very slow.
    When I select a viewport and try to change the VPscale from one scale to the other it takes about 10 minutes to update, which is not what I expect from this Annotative issue.
    What is the thing that I am doing wrong here. I downloaded the cleanup scale utility and have gone through each file, and the problem seems to still exist.
    2006-12
    Big "D"
    3,711
    Default Re: Huge time for processing when dealing with Annotative scale
    Quote Originally Posted by ashrafmfahmy View Post
    Dear All,
    I've not had this problem at all. Usually, when CAD is taking that long to switch viewports or spaces, it's looking for a file or link that doesn't exist. There is a utility to help you find such things, but I can't remember what it is. I'll find it and post it for you.
    Also, post a drawing if you can so I can check it on my end.
    *EDIT* I can't find the link. I saw it here twice somewhere. If anyone knows about the program to detect links to files and clean them up, please let us know.
    Why is it called common sense when it is so rare?
    RevitForum.org
    2008-06
    2
    Cool Re: Huge time for processing when dealing with Annotative scale
    I had a very similar issue that drove me crazy. After much trial and error, what seemed to help was setting my annotation scale to -1. (ANNOAUTOSCALE= <-1>)
    Give it a try, it fixed my down time issues.
    2006-12
    Big "D"
    3,711
    I've got mine set to 4 and don't have any problems. Also check your ANNOALLVISIBLE and set it to 0. I'm not sure if it will make CAD faster, but you won't see all the annoying annotation from different scales when you select a dimension.
    RevitForum.org
  1. Results processing time - any hints?
    By bauskas in forum Robot Structural Analysis
    Last Post: 2011-02-23, 10:03 PM
  2. Huge lag after changing VP Annotative scale
    By Bryan Thatcher in forum AutoCAD General
    Last Post: 2009-03-01, 08:29 PM
  3. Rendering - speed up processing time
    By ajtrahan in forum AutoCAD General
    Last Post: 2007-10-27, 12:14 PM
  4. Extremely long processing time to PDF/DWF
    By msa in forum Revit - Plotting/Printing/Exporting
    Last Post: 2007-10-08, 04:20 PM
  5. How are people dealing with the huge files that 3D creates?
    By IanR in forum AutoCAD 3D (2007 and above)
    Last Post: 2007-02-21, 01:40 PM
