Thread: Lisp routine for Labeling Northing and Easting
    2003-06
    38
    Default Lisp routine for Labeling Northing and Easting
    Not sure this is a proper request, but I'm looking for a lisp routine for labeling northing and eastings... with a catch. We would also like a leader routine incorporated into this. I have a routine that populates a block but the insertion point is right on your pick similar to LDD's way of labeling NE. Then you have 2 do it the old school way!.. label your point, then draw your leader, then move your text. Then finally make any adjustments you need!
    Has anyone done this before?
    Thanks for the help, Mike
    2003-04
    Eastern Washington
    7
    Smile Re: Lisp routine for Labeling Northing and Easting
    i think i've got what you need, see attached
    LabelPoint_2.lsp will display 2 decimal places
    LabelPoint_4.lsp will display 4 decimal places
    Type "lp2" or "lp4" to initiate (without the quotes, of course)
    These both will put an arrowhead at the point you want to label and let you choose where you want the text to be.
    hope this helps............Jim
  1. ID Northing/Easting In C3D
    By jimmyhill in forum AutoCAD Civil 3D - General
    Last Post: 2016-01-26, 11:00 PM
  2. 2013: LISP Routine for adding Coords / Leader / Northing + Easting to Drawing
    By Wayne.Tappe in forum AutoCAD General
    Last Post: 2013-12-11, 02:10 PM
  3. labeling northing & easting on an alignment
    By Maverick91 in forum AutoCAD Civil 3D - Alignments
    Last Post: 2012-03-29, 04:02 PM
  4. Northing & Easting
    By gmarshall.222707 in forum Dynamic Blocks - Sharing
    Last Post: 2009-08-11, 10:02 PM
  5. Northing & Easting Miss Surveying Lisp routine
    By amazingb2003 in forum AutoLISP
    Last Post: 2008-04-23, 06:45 PM
