I have a dynamic block that was written using R2007 and used with R2008 with out any problem. When I open a drawing in R2009 the attribute size is ok. But when I insert the block again the attributes are tiny.
Is there a setting that I need to check?
I uploaded a sample of the block that I'm using. I erased most of the dynamic work from the block so it is very basic.
Chris
