Summary: Surface Elevation Analysis to be saved as a style.
Description: Surface Elevation Analysis to be saved as a style.
How Used: When using Surface Elevation Analysis (color banding), you should be able to set the elevation min/max criteria and the colors associated to those ranges ONCE, then save it to a surface style. You should also be able to insert an additional min/max range without having to start over with changing the elevations and colors. (ie, I start with 10 ranges in 2ft intervals and need to add an additional 4 ft (2 ranges). I have to change the 10 to 12 and start over.)
Feature Affinity: Styles
Submitted By: Trey HAir on March 12, 2008
